Tire Rub
Tire Rub
Hi everyone!
The driver's side front tire rubs on GT trim when wheel is turned to the right. Current tire & wheel setup:
245/50/16 on 16 x 8 Cobra style rims (all the way around). 1/4" spacers added (all the way around for uniformity) to allow center caps to fit in front. Tire rubbed on front driver's side before and after spacer was installed. Mike (MJR46 on this forum) and I took a look at the situation last night... Seems there are a couple options; I don't really want to cut into the trim, so I'll rule that out right away... Less wide tires, as Mike suggested, seem to make the most sense...does anyone know, from first hand experience, if 225/50/16 tires will fit on my 16 x 8 rim, and if this will stop the rub on my 1989 Mustang GT Convertible?? Any help would be most appreciated. Thanks!
Pic removed
Your car has some pretty severe suspension problems. If I were you I'd remove the spacers. You might want to bring your car to an alignment shop. Can you post a picture of your car from the side, with the wheels straight?
Also, you clearly know nothing about tire sizing. Please go do some reseach (google how to read tire sizes). A 225/55/16 is a 25.7" tire, which is stock (correct).
Eric the middle number is the sidewall height, if you went with a 225/50/16, it may give it the dragster effect = higher in the back , lower in the front to balance it out addermk2 is right a 225/55/16 would be the first place to start, however, let me check my rack at the shop, I may have a 225/55/16 we could use as a test tire the next time you come up
I know that..........I put it plain and simple so he could understand that, that is where you look in reference to sidewall to tread width ratio.........is that better to you??
