Coolant system flush
Used the search function, didn't find an answer I could use. Anyway, changed the thermostat and flushed the coolant system. Just wanted to know how long I sould let the car run to ensure that all new fluids were mixed well?
That's what I did.. I just wanted to make sure that all the coolant in the block was the same "mix" that I tested in the rad. after flushing.. I did the flush with distilled water until clear and filled with Prestone straight, then 50/50, run for 20 minutes ('stat open, heater blowing hot) tested the coolant, all good....
Thanks
Thanks
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
