347 stroker cam question!
oh guys i took my car to the dyno today for the firts time and it put out 382whp @ 5800 . i was told i need to change out my cam to make good power.. is 382whp good or decent?? my set up right now 347 stroker 10.1 trick flow hi port head with 2.08 in take valves ** 236 xfi comp cam** 1.7 rokers trick flow r intake 75 mm TB 95mm maf for 50lbs injectors mac 1 3/4 long tube headers with 3" to the back. im after a good cam for NA or a good cam for boost.. or will this cam b good for boost? i have a vortech v1 sitting in my shop for it but im not sure what way to go..
don't force feed it..as stated cr to high.......contact ED at www.flowtechinduction.com and he will set you up with a good cam, a tight lash solid roller might be in line.....get some more rpm out of it and there will be the extra power needed.
ive had the charger on last year and had no problems at 8psi .. i was told as long as i dont go past 10psi ill be ok.. i have been looking at a Anderson N-91 for my set up
AFM N-91 240/248 .576/.576 110 106 power range 2800-6900rpm
my cam now.. 236 XFI 236 248 0.579 0.579 114 power range 2500-6100rpm
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
