5.0 suspension question, k member brace & strut mounts
Old 02-23-2012, 09:16 PM
epic4444
epic4444's Avatar
Default 5.0 suspension question, k member brace & strut mounts
Hey so I got a 90 LX, and my mechanic installed new struts and shock and springs, I bought 2 strut mounts but he said he didn't need them because I also put on a caster kit, is this true?? Also I'm wondering if my car has a k member brace , my front end makes a annoying popping noise and someone old me it was possibly my k member brace since I know fosure it isn't my tie rods/ball joints/sway bar
Any help appreciated
epic4444 is offline
Old 02-24-2012, 07:29 AM
Tony71502
Tony71502's Avatar
K member brace bolts onto the k-member under the rear side of the engine. It is not a stock piece, take a look and you will know if it is there. It would not ever make noise if unless the bolts were loose.
Tony71502 is offline
Old 02-24-2012, 11:51 AM
AdderMk2
Banned
AdderMk2's Avatar
Caster/camber plates ARE strut mounts, and they are likely the cause of your popping noise. Learn to live with it.
AdderMk2 is offline
Old 02-24-2012, 12:45 PM
Tony71502
Tony71502's Avatar
Now that I remember, I had an annoying noise when I occasionally hit a bump. Turns out the driver's side strut was not tightened to the caster camber plate the whole way. Just a quarter turn loose. Tightened it and viola, church mouse.
musnicki
09-23-2015 07:11 AM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: 5.0 suspension question, k member brace & strut mounts
