help with smog?
help with smog?
Hey there guys, quick set of questions for everyone.
I just took my 86 gt in for a smog and failed. It passed 2 years ago with flying colors and now I am having some problems
1.) It failed the idle test putting out around 500 hc at idle, while only putting out 19 at 2500 rpm test.
2.) This is a list of "smog" related parts that have been replaced in the last few months leading up to the smog inspection. I have a few that have yet to be replaced so maybe they're the culprits: new egr valve+solenoid, vacuum solenoid, coil, wires, plugs, k&n air filter, o2 sensors, tps (and calibrated within specs)
what I havent replaced is the PCV valve, and fuel pressure regulator.
Any thoughts? Any ideas of what could be causing high emissions at idle and how I can fix the problem?
Many thanks
Many thanks
Really? Huh....why didnt I think of that. This whole time i thought something else was going on....but its never had problems passing before...I was worried
Thanks, i'll drive er hard next time I do go into the smog station to test her. Is there a time limit or mileage that should be driven before going in?
lol ****ing wow. Yes i know what operating temperature means. No, the car did not sit outside for hours. I drove it about 13 miles from my house, left it running as I pulled into the stall and it sat idling until the paperwork was started
