valves, valve cover gasket, sludge(?) questions (with pics!!!) - Page 2 - MustangForums.com
Old 03-20-2012, 03:26 PM   #11
mustangGT86_05
mustangGT86_05's Avatar
Not to mention little knicks that may have been overlooked, thay can cause the headgasket to go too
mustangGT86_05 is offline   Reply With Quote
Old 03-20-2012, 03:29 PM   #12
9550
9550's Avatar
suppose i do the compression test and/or leak test and they come back good.
should i still be concerned about the straightness of the deck or head?
9550 is offline   Reply With Quote
Old 03-20-2012, 04:19 PM   #13
mattdel
mattdel's Avatar
It used to be nearly mandatory to have them both checked any time you take the head off. Not so many people do it now-a-days with aluminum blocks/heads, but it something to look at closely if you have continual blown gaskets.
mattdel is offline   Reply With Quote
My 5.4 4 valve Swap begins... 2002 GT Gary Ugarek 4.6L (1996-2004 Modular) Mustang 63 12-11-2015 03:01 PM
06 Mustang Gt Hesistaion mirandaandjimmy 4.6L V8 Technical Discussions 20 11-16-2015 09:51 AM
EFI to CARB conversion problem, running like a PIG..vacuum problem? YoungStangsMan 5.0L (1979-1995) Mustang 15 09-05-2015 08:01 PM
1989 starting problems, engine won't turn over. KEM Motorworks 5.0L (1979-1995) Mustang 20 08-14-2015 11:13 PM
302, 89, bullitt, change, cover, gasket, gt40, gunk, heads, lots, motor, mustang, oil, sludge, valve
