Fuel gauge not working after new tank install
I just installed a new tank, a new fuel pump and new sending unit. I used the old fuel gauge from the last tank.
I have only added maybe a gallon to the tank, but the guage says I have a full tank
Is it just because I havent filled it all the way up yet?
Stuck at full is one of two things in this scenario: Either the wiring for the sending unit has become fully grounded, or the sending unit was installed slightly off, and the swing-arm is stuck up. I recall the inside of the tank where the sending unit goes is quite tight, you may be stuck inside.
Thats how almost all tanks on all cars are designed. What you wanna do is get yourself a 2 or 3 foot extension bar for the ratchet, use the bar + socket to push the bolt up into the hole as its in the strap. Takes a little muscle but it's purposely designed that way.
