Fuel Pump (I think) question
Old 04-05-2012, 11:00 AM
DOTC
DOTC's Avatar
Default Fuel Pump (I think) question
I have a loud whine coming from what sounds like the gas tank. The whine gets louder as you rev the motor.. any suggestions?
DOTC is offline
Old 04-05-2012, 11:01 AM
DOTC
DOTC's Avatar
90 LX if that matters.
DOTC is offline
Old 04-05-2012, 11:22 AM
Vazura
Vazura's Avatar
Fuel pump like you said, replace it
Vazura is offline
Old 04-05-2012, 02:51 PM
Bubba 95SN
Bubba 95SN's Avatar
R&R the fuel filter and see if sound changes any.
Bubba 95SN is offline
Old 04-06-2012, 08:03 AM
DOTC
DOTC's Avatar
R&R? Another question. LRS didn't have any stock FF the last time I looked. Would it mess something up if I went with a performance pump? Cars stock right now.
DOTC is offline
Old 04-06-2012, 07:09 PM
Bubba 95SN
Bubba 95SN's Avatar
R&R, remove and replace. FF Motorcraft are available at most parts house. Most will recomend a 255lph pump.
Old 04-06-2012, 07:22 PM
mattdel
mattdel's Avatar
No one tied together the fact that the whine shouldn't change with engine speed? All pumps whine, thats how you know they're working. I think the pump is fine, I think it's a voltage issue.
mattdel is offline
Old 04-07-2012, 10:03 AM
DOTC
DOTC's Avatar
Can you give me the quick and dirty on what might cause a voltage problem?
DOTC is offline
Old 04-07-2012, 02:41 PM
mattdel
mattdel's Avatar
Bad regulator on the alternator, bad ground to the pump, corroded power connection. Variations in the whine indicate a not-so-strong connection to the power or ground source.
A whine is subjective. It can be good or bad. It all depends on how pronounced it is, and what the output pressure is at.
mattdel is offline
Old 04-07-2012, 03:56 PM
DOTC
DOTC's Avatar
It has gotten louder since I've owned the car. Started off as a low whine and now its louder than the exhaust. If I'm going to drop the tank I guess I might as well replace the pump. Most of the things on the car are original, I wouldn't doubt if the pump is as well. The ALT is new, so I'll check the grounds when I drop the tank. Thanks again.
DOTC is offline
Tivo304
08-28-2023 12:19 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Fuel Pump (I think) question
