88 5.0HO won't idle
Old 04-13-2012, 11:36 PM
FMLX3
FMLX3's Avatar
Default 88 5.0HO won't idle
Need some help, I recently purchased a 88 saleen as a project car, it will start but dies at idle. I ran the codes and a 34 and 87 came up.
34= EGR
87- Fuel pump relay
I think!
Could these cause the problems or should I be looking at something else?
Any help would be greatly appreciated
FMLX3 is offline
Old 04-14-2012, 12:35 AM
enix187
enix187's Avatar
What does the car do if you feed it throttle? how does it run while its running, need a bit more to go on man
enix187 is offline
Old 04-14-2012, 09:28 AM
FMLX3
FMLX3's Avatar
It will start if I feather the throttle and keep feathering but as soon as I let off it will die out. I have checked the timing and it is at 10 degrees and I have spark across the board. I checked fuel pressure at the rail and it squirts across the garage. I don't have a gauge. I was wanting to eliminate the smog pump, should I block off the egr and avoid spending the eighty dollars. The other question is are the fuel pump relays a two stage relay, the fuel pump kicks on with key on and the relay also clicks but then clicks off but should it still keep power to the fuel pump?
I am fairly new at the whole car thing so please bear with me.
FMLX3 is offline
Old 04-14-2012, 09:31 AM
FMLX3
FMLX3's Avatar
It will not maintain RPM, it jumps around even with a steady foot, with a little intake pop. I have also checked vacuum lines across but I could have missed something.
Thanks and hope this info is a little better.
FMLX3 is offline
Old 04-15-2012, 11:06 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
Try taking off the egr valve to make sure it is not stuck open.
TrimDrip is offline
Old 04-16-2012, 03:02 AM
Harriet61
Harriet61's Avatar
Harriet61 is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
ChampInSD
10-02-2015 04:55 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: 88 5.0HO won't idle
