Stang having trouble red lineing
Old 04-17-2012, 02:37 PM
javila2468
javila2468's Avatar
Default Stang having trouble red lineing
I've noticed that my car has been having trouble red lineing for some reason. I don't know if it has to do with the spark plug gap, ignition wires, fuel pump, fuel pressure or timing. Any advise will be greatly appreciated.
I have my plugs gaped at .44
I have my timing set at 13*
I am running stock ignition w/MSD cap and Accel 7mm yellow wires
stock fuel pump
and fuel pressure hasn't been checked to see if its set at correct setting.
javila2468 is offline
Old 04-17-2012, 05:13 PM
newpony
newpony's Avatar
What are your mods and in what gear are you trying this? i went pretty close to redine if i did not hit it, i was not trying to there's power loss up there depending on what you are doing.
newpony is offline
Old 04-18-2012, 08:50 AM
mattdel
mattdel's Avatar
Usually, the #1 culprit behind "having trouble redlining" is the coil. It can't keep up with demand and hits a brick wall, so to speak.
mattdel is offline
Old 04-18-2012, 09:07 AM
javila2468
javila2468's Avatar
Typhoon upper and lower (ported), CAI, 24# injectors w/c&l 76 mm MAF, shorty headers, adjuster fp, 1.7 cran cam rockers, 3:73 rear-end, full H-pipe 2.5in flowmaster dumps, 70mm TB, 5 speed. and its doing this in first gear. it redlines at 6,000 but it has trouble getting to about 5,200rpms. it will hesitate for a second or 2 at about 4,900 rpms and then it will redline.
Old 04-18-2012, 12:13 PM
luckythirteen13
luckythirteen13's Avatar
Stock heads? What's the afr at that rpm?
luckythirteen13 is offline
Old 04-18-2012, 02:35 PM
mattdel
mattdel's Avatar
I say again. Coil.
mattdel is offline
Old 04-18-2012, 05:19 PM
javila2468
javila2468's Avatar
stock heads. i will swap out the coil and give that a try.
Old 04-18-2012, 05:42 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I would think fuel filter too. If they get clogged pretty bad, it won't redline. Take out a plug and see if they are white.
TrimDrip is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
TCStangerv6
10-11-2015 05:57 PM
Bokeo
10-10-2015 08:28 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: Stang having trouble red lineing
