Performance 302 mustang help
I just need some input, or maybe some website were i can get specs, such as, rocker arm ratio, stud mount or pedestal, what camshaft comes iin the HO mustang engine....also here is my plans,I am aiming to get around 450+hp when im ddone with this kit
1987-93 Mustang 5.0L Top End Engine Kit with Satin Professional Products Typhoon Intake, Patriot Heads And Trick Flow Stage 1 Camshaft, along with a full exhaust system, and 1.7 rocker arms. i Just wanted some input along with if anyone knows if this is a good top end kit, mainly with the intake manifold, I am also stroking it to a 347. Just wanted some input and possibly a place to get specs for the mustang.
Thanks in advance
Thanks in advance
how so, air intake manifold, rocker arms, cam shaft, heads, along with full exhaust system, cold air intake, and throttle body, stroked to a 347. I figured it would be at least 450....and im not sure the stock cam in the HO version, so im not sure how much to expect with that, but I figured i would have enough
Put it this way, 400 rwhp N/A on a 5.0 is hard to do. Requires a lot of high end parts that ruin the cars ability to be driven daily. The 415 bhp 5.0 on the market today is a completely different animal than the windsor 5.0. They coyote 5.0 has the advantage of 4V per cylinder, dual cam timing, and a ton of other modern technological marvels that older engines just don't have.
not all true bc i know a man arther bryant that can get 1000 plus out of a 302 he's been doing it ever since the 60's his wife was a 3 time back to back champ out running big blocks with a 302 he is helping me with my 302 build and i was going to go with a 351 and he talked me out of it bc the blocks are not as good as a 302 block and he dont only build fords he's built every thing
