86 stang shakes
Old 05-09-2012, 09:34 PM
joesmoe42
joesmoe42's Avatar
Unhappy 86 stang shakes
i had a new clutch kit and clutch cable put in now when i go and pull the clutch out . the car shakes if i run the rpm about 2000 it only really shakes just a little it only does . it in 1st flyweel re surface the shop said they did everything they said the clutch pedal pivot shaft was bent i looked at it . so i put a resto50 quadrant in the pawl was way up but that didn't do much it doesn't shake as much . is the clutch not adjust right before the new clutch was put in it was fine but the clutch was bad any help please thanks
joesmoe42 is offline
Old 08-08-2012, 05:04 PM
joesmoe42
joesmoe42's Avatar
Angry 86 clutch
please help had a clutch put kit put in car was making a ticking sound in clutch took it back guys say it the clutch pedel shaft so he put that in drove fine for 1 day now the sounds back but if i just put my foot on the pedel it goes away does anyone know what going on thought maybe just the clutch cable too lose dont want to mess with it untill sure please help
Old 08-08-2012, 05:40 PM
mattdel
mattdel's Avatar
throwout bearing is bad. tell the mechanic he's a schmuck and force them to redo it.
mattdel is offline
Old 08-08-2012, 07:06 PM
dawson1112
dawson1112's Avatar
wow the shaking could be from a poor flywheel reservice . Or they didnt get the clutch plate lined up. i would definatly take it back and make them redo the whole thing. The clutch pivot shouldnt make it shake. The tb could definatly be causing the ticking sound your hearing .
dawson1112 is offline
Old 08-08-2012, 08:57 PM
Bubba 95SN
Bubba 95SN's Avatar
Clutch plate not lined up? OP says he has been driving car. Not correct answer. TOB is likely culprit, adjust cable. 2K vibration...at speed or sitting still?
Bubba 95SN is offline
Old 08-08-2012, 10:07 PM
joesmoe42
joesmoe42's Avatar
ok guys let me start from the top took it in for a new clutch kit they put it in drove about 2 days it started shaken when i started off but if i got rpm too around 2k no shake so i took it back he said the shake because the pedal shaft bent so he put in new shaft drove it about 30 miles started it up this morning heard that ticking sound and it coming from the clutch but if i just put a little pressure on pedal it stops don't hear it driving but at a stop in neural i hear it it not a big tick couldn't i just tighten the cable up some to stop the ticking thanks everyone
Old 08-09-2012, 09:06 PM
Bubba 95SN
Bubba 95SN's Avatar
Take out a little slack in cable and listen.
mtgldr
02-03-2024 09:00 PM
4cylinderplus2
10-09-2020 07:45 PM
Roxon68
03-17-2016 08:13 PM
11-18-2015 01:34 PM
Bokeo
10-10-2015 08:28 PM
Quick Reply: 86 stang shakes
