1989 302 flooding after running
I have recently rebuilt my 302 and now it idles great at about 750 rmp but my problem is after it idles to operating temp and i shut it down i have to put gas pedal to the floor to get it to start back up and if i drive it and slow down it stalls out and same think i have to put the gas to the floor to fire back up any ideas would be great i have tried to clean maf and iac still not right
I tested the ect and with the key off and set my voltmeter to 200k i have only 20.1k and when i turn the key on i have no reading at all with the sensor plugged in or unpluged could i possible have a bad wire
On the link it says it is a black and wire wire and a light grey and yellow wire but i have to different plugs right next to each other with one not plugged in anywhere and never has been and one has a black and white wire and a green with yellow and the other one not plugged in has a grey with yellow and a red wire could the wrong one be plugged in
I tested the ect and with the key off and set my voltmeter to 200k i have only 20.1k and when i turn the key on i have no reading at all with the sensor plugged in or unpluged could i possible have a bad wiring or a bad sensor
Galactic
04-29-2019 02:56 PM
