94 mustang super hard clutch problem - MustangForums.com
Old 05-17-2012, 04:42 PM   #1
M Beach
Question 94 mustang super hard clutch problem
My clutch petal is so hard to push down it literally hurts. I am now on my third clutch and second clutch cable and the problem still exists. I really need to know that I am not the only one in the world with this problem.. any info would be so much appreciated
M Beach is offline   Reply With Quote
Old 05-17-2012, 06:20 PM   #2
mattdel
mattdel's Avatar
Bent fork maybe, maybe broken fork pivot. Really everything in the clutch system can make a stiff pedal if it fails, gonna have to dig in and find it.
mattdel is offline   Reply With Quote
Old 05-17-2012, 06:44 PM   #3
M Beach
Ok thank you .. now I can know what to ask a man to look at next because replacing the clutch and also the clutch cable was obviously not the problem.
Old 05-18-2012, 11:54 AM   #4
M Beach
One more question...would a bent fork cause the firewall to bow out when the clutch is pushed in?
Old 05-18-2012, 12:19 PM   #5
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
don't be so sure of the clutch cable thing, I went through three cheap **** oem ones before ordering a steeda one and quick release set up and cured the issue, make sure the firewall is not cracked as well and that cable is routed properly and that clutch fork is fine/ not bent and that the retainer that the TOB rides on is not grooved causing it to bind, if it is, time for a steel one if not equipped already.
mjr46 is offline   Reply With Quote
Old 05-18-2012, 12:55 PM   #6
Tony71502
Tony71502's Avatar
Mine was incredibly hard when I bought my car. It was the corroded stock cable binding inside the sheath. New OEM cable and some lube on the pedal assembly and now it's easier to use than the one on my brand new 4 cylinder ranger.
Tony71502 is offline   Reply With Quote
Old 05-19-2012, 12:05 AM   #7
M Beach
Ok thanks everyone
Old 06-12-2012, 09:43 PM   #8
Grn95GT
My new clutch, which is a stage 1, started out like that for the first week, then it loosend up tramendously. If you just got the clutch i would say it is normal, if youve had it for a while, i dont know wha tot tell you
Grn95GT is offline   Reply With Quote
Old 06-13-2012, 02:30 AM   #9
stangrookie302
I had that problem with my 93. When I bought it, the previous owner put in a repset gold luk clutch and it was stiff as hell. He told me to drive it for a couple weeks and I did. The problem was still there and so after a while my synchros went out in 2nd gear. My clutch was so stiff on my cable that the cable wasn't working properly. Depends on what kind of clutch you have and transmission I would get a hydraulic clutch assembly. But you really don't know until you crack the case.
stangrookie302 is offline   Reply With Quote
Old 06-17-2012, 01:41 AM   #10
M Beach
thanks guys...all I can do is rely on a mechanic now as it sits in a parking lot because I cannot even get it to shift into gear now... cant drive it so I am taking it back to the last mechanic that replaced the cable.. so tired of it .. I love my mustang but whats the sense if I cant even drive it.. sorry, Im just so fed up and I dont trust mechanics, they see a female drive in and see dollar signs. Not one has helped me yet. thanks again
god help me. I need a bellhousing for a tr3650 Jskeezy84 4.6L General Discussion 5 09-08-2015 02:40 AM
This GT500 Super Snake Gallery Makes Any Day Better MustangForums Editor S197 Shelby Section 2 09-03-2015 04:04 PM
New alternator-battery light flashes during hard acceleration Soldier GT 4.6L (1996-2004 Modular) Mustang 12 08-20-2015 10:42 AM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 10:22 AM
1995, 50, 94, bullit, clutch, depress, doesnt, ford, gears, gt, hard, mustang, mustangs, pedal, sticking
