shifting prblems
Old 05-18-2012, 11:22 AM
clark8342
clark8342's Avatar
Default shifting prblems
I have an 9 mustang LX, just had tranny(5 speed) rebuilt new second gear and syncho's put I and still had problems between first and second, took back rebuilt again, all done by repuliable person and just don't seem right, have not got a real grind but a little one now between second and third, scared to get on it,replaced the stock pendant with an aluminum one and I did put in a hurst short throw shifter.......what may be wrong clutch is adjusted toward the tight side(new spec 2 clutch) any suggestions?
clark8342 is offline
Old 05-18-2012, 07:49 PM
enix187
enix187's Avatar
what kind've fluid are you running in it? other than the clutch not releasing fully there is no reason a properly rebuilt t5 should crunch.
enix187 is offline
Old 05-18-2012, 11:25 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
what do you mean by tight side?
TrimDrip is offline
Old 05-19-2012, 07:06 AM
clark8342
clark8342's Avatar
To: enix187 - Royal purple Max atf is the transmission fluid I used...
To: TrimDrip - There is no free play and no slop in the cable. I was told I am supposed to have some free play in the peddle, but when I do have free play in the peddle my clutch engages right off the floor.
Old 05-19-2012, 12:56 PM
mattdel
mattdel's Avatar
did you put the cable in the correct spot on the quadrant?
mattdel is offline
Old 05-22-2012, 07:32 PM
clark8342
clark8342's Avatar
i put the cable where it looks like the only way it would go on,the only wrong was i did not put the fire wall adjuster in.
as i shift i will put light pressure on the shifter toward 3rd gear and it will like push back and then slide into gear, some times it seems right but not allot,the other gears dont give me any problems, it almost feels like my clutch isn't disengaging all the way, but im scared to tighten it any more and screw up the throw out bearing, also there is only about 300 miles on it, could it need more time to get broken in?
Old 05-22-2012, 08:40 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
You want the firewall adjuster. It makes adjusting the cable a whole lot easier. I used my stock cable with the firewall adjuster and I love it.
Yeah, there should be no slack in the pedal. If it is engaging at the floor, it probably needs adjusting.
TrimDrip is offline
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: shifting prblems
