92 idling problems
92 idling problems
hi
i have a 1992 mustang gt hatchback and it has a problem with how it idles
most of the time, it will only idle rough when you start it up cold and the choke deactivates(it runs fine when the engine is cold and the choke is on)
it also has a problem where when it is run at a low rpm, it tends to "miss" and the car kind of jerks a little bit when it does (again when the choke is off)
any ideas on what these problems could be?
