Converter stuck to crank
Old 05-29-2012, 06:24 PM
87Stallion
87Stallion's Avatar
Default Converter stuck to crank
Im trying to remove my tranny (C4) The tranny grenaded and now the converter wont come loose from the flexplate. And yes Ive removed the 4 nuts on the converter studs.
Ive tried pry bars and lubricant but she wont budge.
Any tricks or tips? I dont care if converter or flexplate gets damaged. Im going back to manual.
87Stallion is offline
Old 05-29-2012, 10:30 PM
capri debris
capri debris's Avatar
Smack it with a BFH.
capri debris is offline
Old 05-30-2012, 09:30 AM
mattdel
mattdel's Avatar
Try and get a prybar up near the center where the splines are, then use a hammer on the prybar. 1 good solid whack should be all it needs, if it's stuck beyond that then you'll probably have to cut the bell of the C4 and get more leverage.
mattdel is offline
GPR
12-16-2015 12:21 PM
jstrothe
09-24-2015 12:17 PM
rafotree
09-22-2015 03:55 PM
LivingInThePast
09-16-2015 12:20 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: Converter stuck to crank
