Ok....what the hell is going on?
Old 06-06-2012, 01:04 PM
Dj_Seph
Dj_Seph's Avatar
With new radiator pressure is held at a good 18psi. It still overheats but not as badly. The coolant frothes at times so I'm guessing I have a head gasket blown on the exhaust side.
Dj_Seph is offline
Old 06-06-2012, 01:58 PM
oatburner99
oatburner99's Avatar
Let me ask you this, when you filled the radiator full of coolant, did you pull the cap off, and run the car (at a higher RPM than idle) until it got hot and the thermostat opened up and you could visually SEE it flowing through the radiator at the cap opening? Wondering if you have air trapped somewhere?
When I did my H/C/I, the above steps is what I did...once I could see the coolant flowing through the radiator, I topped it off, and popped the cap back on and then I was done. Also are you sure that you have the correct water pump? There are 2 different models, one is reverse flow (standard 1979, 1982-1993) and the other is standard rotation for serpentine belt system (80-81) I think:
OEM "reverse flow"5.0 W/P
http://www.latemodelrestoration.com/...low-Water-Pump
Standard flow 5.0 w/p:
http://www.latemodelrestoration.com/...er-Pump-V-Belt
oatburner99 is offline
Old 06-08-2012, 12:00 PM
Dj_Seph
Dj_Seph's Avatar
I got the one from O'REilly's that was a CP5038.
Dj_Seph is offline
Old 06-10-2012, 12:51 AM
kmajka
kmajka's Avatar
check the plugs and see if you are burning water and block test it.
kmajka is offline
Old 06-10-2012, 06:11 AM
302army187
302army187's Avatar
burp it bitch.
and I used a mark VIII fan..... kinda big, but it works well on my ****, even when I'm beating the **** out of it, over and over, for my videos. Will get up to 200-210 while screwing around, and in like 3min the mark VIII gets it to 170-180 agian. (normally around 170 when just driving around easy. have 180 thermostat.)
302army187 is offline
2007CalSpec
12-13-2020 11:42 AM
drfister
05-03-2018 10:38 PM
Sminemann
09-17-2015 09:24 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Ok....what the hell is going on?
