Ok....what the hell is going on?
Old 06-01-2012, 02:44 AM
Dj_Seph
Dj_Seph's Avatar
Default Ok....what the hell is going on?
So. I fixed the previous problems. The smoking was from a severely warped flywheel that was burning the clutch. Rear main wasn't broken but I replaced it anyways.
Also, turns out the waterpump didn't seize, the damn power steering pump AND smog pump seized. Easy fix and I changed the water pump anyways.
Well, anyways, in haste, my dumbass routed the belt so that I bypassed the smog pump but with the configuration I did, the waterpump was turning the wrong way causing overheating. Joy. I fixed this and now the car keeps overheating no matter what. I can see flow in the radiator but nothing. No coolant is hitting the ground, in the oil, or coming out the tail pipe.
What is going on? I pressure tested the Mishimoto Radiator that is in there and I can't get pressure out of it. There's a very audible hissing sound where the upper radiator hose is. There's also evidence of a leak, it would seem. Could this be the problem? I have a nice big Fluidyne to replace it with so I'll see if that fixes things.
Also, after having to wrestle with working around the fan clutch and such, I'm going electric. My first 5.0 already had this done and I can see why. The fan clutch just makes doing anything on the front of the motor a PITA. Only problem is I just keep seeing Mishimoto POS dual fan setups and overly expensive black magic single ones. Is there anyone else out there that makes a dual fan setup or a single fan setup that could handle let's say, a 650hp turbo 331 stroker? ;D Yes, a build thread will be coming to a forum near you.
Dj_Seph is offline
Old 06-01-2012, 05:34 AM
parrfive
parrfive's Avatar
Yep flexalite 12" duels with an aluminum shroud. My 347 makes around that with the spray and it stays around 190. I run it with key on power no relays.
parrfive is offline
Old 06-01-2012, 05:53 PM
Dj_Seph
Dj_Seph's Avatar
Link? I can't find a flexlite dual setup anywhere.
Dj_Seph is offline
Old 06-03-2012, 02:39 AM
Dj_Seph
Dj_Seph's Avatar
Car still overheats with new radiator and water pump. I'm guessing head gasket yet there's no milky oil or smoke.
Dj_Seph is offline
Old 06-05-2012, 07:20 AM
Tony71502
Tony71502's Avatar
Does the rad get really hot? Bad thermo?
Tony71502 is offline
Old 06-05-2012, 02:21 PM
Dj_Seph
Dj_Seph's Avatar
Yes, the radiator does get really hot. I've changed the thermostat three times. My dad suspects a pinhole leak on the exhaust side. The car will go to overheat but then stop between the N and O on normal. If I go wot, it'll go down but when I start cruising it'll go back up high and fluctuate between the middle and near overheating.
Dj_Seph is offline
Old 06-05-2012, 10:27 PM
tomnh
tomnh's Avatar
try changing your temp sender.
tomnh is offline
Old 06-05-2012, 10:36 PM
Dj_Seph
Dj_Seph's Avatar
Both are new.
Dj_Seph is offline
Old 06-06-2012, 04:45 AM
caaraa
caaraa's Avatar
Gush, this is just perfect!
caaraa is offline
Old 06-06-2012, 06:07 AM
oatburner99
oatburner99's Avatar
Here's my thread for the taurus fan I installed on my coupe:
http://forums.corral.net/forums/gene...completed.html
Radiator cap? petcock fitting? (trying to think of things that would leak, not allowing a pressure build) any drips behind below the water pump (weep hole?)
oatburner99 is offline
Quick Reply: Ok....what the hell is going on?
