Flexalite toggle...
Old 06-01-2012, 11:53 AM
captahab
captahab's Avatar
Default Flexalite toggle...
A quick question for anyone . If a three way toggle is installed along with the standard thermostat module with a flexalite fan , will I be able to operate the fan with the three way toggle and the thermostatic control ?
Thanks.....
captahab is offline
Old 06-01-2012, 12:34 PM
Tony71502
Tony71502's Avatar
There's always a way, but why would you want to?
Tony71502 is offline
Old 06-01-2012, 07:35 PM
captahab
captahab's Avatar
Thanks for the reply on his.......I appreciate it.
captahab is offline
Old 06-01-2012, 10:35 PM
mattdel
mattdel's Avatar
Might be tricky with a 3 way, depending on the design of the fan controller you could backfeed power into it and power it up without wanting to. I'd see if you can find a 2 way toggle switch with 5 prongs, to feed power to the already grounded fan, or feed a ground to the already powered controller, or vice versa depending on your setup.
http://www.waterskis.com/500624-p/ma...gle_bl_624.htm
mattdel is offline
351GT
07-14-2010 08:33 PM
Hamutoff
12-19-2009 12:22 AM
veto227
10-08-2006 07:54 PM
jameswehner
09-14-2006 04:40 AM
Quick Reply: Flexalite toggle...
