wont start now?
Old 06-13-2012, 03:38 PM
  #21
mattdel
mattdel's Avatar
Its the pump. Sorry someone more knowledgeable didn't come in here sooner.
The stock rated fuel pump can put out 80psi when its fresh. Pressure regulators lower the pressure when they're working. When they aren't, the pressure is high. Your problem was never the regulator, it's always been the pump.
mattdel is offline
Old 06-13-2012, 09:06 PM
  #22
Js88lx
Js88lx's Avatar
Whooo.., thanks imma switch it out 2day!! Ill let you know!!
Js88lx is offline
Old 06-14-2012, 08:33 PM
  #23
Js88lx
Js88lx's Avatar
Im cursed!! I wanted to take my car to my folks house 2day kuzz thats where i do my mechanics.., well as im on my 5-8 crank my starter takes a crap.., It got stuck and all i hear is click, click strait from the starter..., AAHHHHHH...AAAHHHH
Js88lx is offline
Old 06-16-2012, 03:24 PM
  #24
Js88lx
Js88lx's Avatar
Well still no luck., i dont know what to do from here? Iv changed the fuel pump, filter, regulator., oh and starter because the other one decided 2 go out since i keep crankin and crankin. What should i look 4 here.,? Im beggining 2 think that my prob is some small stupid thing., im done 4 now!
Js88lx is offline
Old 06-16-2012, 03:48 PM
  #25
mattdel
mattdel's Avatar
Did you recheck your fuel pressure #'s after installing the new pump? I'm curious what they are. As said before, you should attain optimal pressure(mid 30's) as soon as the pump turns on. You were getting readings of 10 before.
One last thing that could cause a drop in pressure is the pump feed hose. The 3 inch section of rubber hose that connects the pump to the pickup tube. If that leaks, you'll have a pressure drop like you've described.
mattdel is offline
Old 06-16-2012, 06:56 PM
  #26
Js88lx
Js88lx's Avatar
I havent checked fuel pressure again but now i have to! When i changed the pump i also changed the feed hose because the old one was terrible, so cant be that. How about spark.?
Js88lx is offline
Old 06-16-2012, 08:41 PM
  #27
mattdel
mattdel's Avatar
Don't jump the gun yet. Verify the pressures are correct. See if you can get a distinguishably different pressure tester, just to be sure.
mattdel is offline
Old 06-16-2012, 09:43 PM
  #28
Js88lx
Js88lx's Avatar
Ok..., the last gauge i used was brand new from autozone.., i dont want to buy one since iv never really needed one til now..., anywhere else i can loan a tool?
Js88lx is offline
Old 06-16-2012, 10:47 PM
  #29
mattdel
mattdel's Avatar
Oh well if its brand new, no problem then. Get it again.
mattdel is offline
Old 06-17-2012, 12:06 AM
  #30
Js88lx
Js88lx's Avatar
Will do.., i work alot thats why i take full advantage of my days off..., i will be off early manana so ill let you know the #'s but what if i still have 10psi on prime..? I have no leaks, no smells.
Js88lx is offline
Quick Reply: wont start now?
