Codes?
Old 06-07-2012, 07:18 PM
taino
taino's Avatar
Default Codes?
I hear many talk about looking up codes, How is this done?
taino is offline
Old 06-07-2012, 11:13 PM
Foureyed
Foureyed's Avatar
Foureyed is offline
Old 06-08-2012, 07:56 PM
Bubba 95SN
Bubba 95SN's Avatar
Visit Joel 5.0, that is all.
Bubba 95SN is offline
Old 06-08-2012, 08:00 PM
taino
taino's Avatar
Joel 5.0 what?
taino is offline
Old 06-08-2012, 09:51 PM
nitrous_bob
nitrous_bob's Avatar
the easiest way is to go to your local pep boys, autozone or whatever and have them scan it for free for you.
the problem is...there are 3 checks you can do and i doubt they will do all of them
the first is KOEO, or "key on, engine off" these are stored codes
then KOER, or "key on , engine running" these are codes it will pull as it runs a self test
then you can do a cylinder balance test, and the computer will assess each cylinder and tell you which ones (if any) are weak
all of it can be done with a paper clip or jumper wire, you use it on the "eec self test" at your firewall on the drivers side
the small single connector needs to be jumpered to the top right on the self test port
(dont just try them all...google for the correct one, because one is power and your sure to cook something if you jumper that to the self test port)
then you have to count flashes, but after a series of flashes for each different test
the KOER are the most important codes IMO
nitrous_bob is offline
Old 06-09-2012, 03:49 AM
Bubba 95SN
Bubba 95SN's Avatar
Joel's 5.0 Electronic Engine Management http://sbftech.com/index.php?... This site has all test proceedures with pictures.
Old 06-09-2012, 09:48 AM
taino
taino's Avatar
Now you talkin, Thanks for the link
taino is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Codes?
