Easy Fuel Pump Relay Fix
On a Foxbody with the relays on the front passenger tire well, you can use a standard Bosch relay which you can pick up at any stereo or auto-security shop. (And if it's a shop you frequently do business with, they will most likely give it you to.) Beats spending $54.99 for one. I was only out $33 for the tow strap I needed to buy.
Just zip tie the relay onto the socket so it stays in place, and then screw it back into the wheel well where the original relay was.
zanemoseley
09-06-2015 12:58 PM
