dash lights
Old 06-22-2012, 10:52 AM
jc44
jc44's Avatar
Default dash lights
my 88 gt dash lights and consoll light went out, fuse is good could dimmer switch be bad, it will still turn on dome light previously when i moved the dimmer switch dash lights would blink and sometimes go out.
jc44 is offline
Old 06-23-2012, 05:48 AM
ttocs
ttocs's Avatar
very good chance it could be your switch going out as they are known to do so, but I would check your fuses again. Don't even bother with the manual take my word for it that it will take you less time to just get down and pull/inspect each fuse then it does to try and figure out which one might be correct according to the manual. I always liked to check the manual after I found a blown one to see what it listed that fuse being hooked up too and 9 out of 10 times the fuse listed had nothing to do with the problem I was having.
ttocs is offline
Old 06-24-2012, 10:24 AM
jc44
jc44's Avatar
Thanks for the info
jc44 is offline
folivier
10-02-2015 05:34 AM
jc409
Convertible Tech
09-26-2015 08:28 AM
09-25-2015 09:06 AM
accarter
09-21-2015 11:56 PM
2015Ecoboost
09-17-2015 01:48 PM
Quick Reply: dash lights
