Welp, back to the drawing board.
06-28-2012, 11:14 AM
Hmm. Is this car MAF or SD?
Also, what kind of coil do you have?
06-29-2012, 12:52 AM
Car is SD. Going to change to MAF when I get it actually running correctly. Also, it's an MSD stock replacement style coil.
06-29-2012, 09:50 AM
Run a code check, see what comes up.
06-30-2012, 03:11 AM
Absolutely nothing comes up.
07-01-2012, 08:48 AM
if its running like ****, dying and everything and NO KOEO or KOER codes, I would be shocked.
replace MSD coil with stock/new to test is MSD is crap, look for vacuum leaks. Try unplugging o2's
07-01-2012, 11:38 AM
Quote:
Originally Posted by
Dj_Seph
Already ordered. Though I wish I could find a 60 buck straight set.
NAPA sells some pretty nice silicone sleeve wires that are <$60
07-02-2012, 05:00 AM
The coil is good. Checked with a good stock one and problem persists. And there's truly no codes. I don't understand it either. Pissing me off.
What will unplugging the o2's do?
07-02-2012, 10:20 AM
Unplugging o2's will put you into a permanent limp strategy mode, narrowing down an issue if it was sensor related.
I think you need to test your fuel pressure.
07-03-2012, 12:28 AM
I'm guessing a burnt/cracked to hell flywheel wouldn't cause these problems, would it?
07-03-2012, 12:42 AM
Wouldn't really affect the engine being able to run. At most it would lose it's balance and cause a nasty vibration, but thats quite a longshot.
