input shaft bearing
Old 07-06-2012, 06:08 PM
Goosepoop302
Goosepoop302's Avatar
Default input shaft bearing
So in taking apart my transmission i have come to removel of the input shaft. while fighting to get this off i noticed there are metal chunks visible through the slot on the meshing ring. now i cannot remove the input shaft because of the metal chunks wedging themselves into the cracks....anyone ever had this happen...if so ideas?
Goosepoop302 is offline
Old 07-06-2012, 06:26 PM
mattdel
mattdel's Avatar
Never had it happen, but I imagine... yank harder. Not gonna hurt anything that isn't getting replaced anyway. I've never taken apart a tranny so don't go yellin at me if this advice breaks it. Matter of fact, let someone else guide the way lol.
mattdel is offline
Old 07-06-2012, 10:07 PM
Bubba 95SN
Bubba 95SN's Avatar
T-5? There is flat spot to get input shaft out............rotate and pull. You will soon find the right spot.
Bubba 95SN is offline
Old 07-06-2012, 11:20 PM
Goosepoop302
yeah i have found the notched area in the smaller gear... i believe one or some of the larger bearings (steel cylinders) have self destructed thats go between the input shaft and rest of the gears...is this possible? again i can see small pieces of something that is clearly not supposed to be broken and lodged in the manner they are.
ill try and get a pic
Old 07-06-2012, 11:43 PM
Goosepoop302
start at the bottom of the picture, above the lowest gear( which is trashed) there is a notch in the meshing gear above it, in the notch is where you can see the small bits that i think are holding the shaft on
Old 07-06-2012, 11:46 PM
Goosepoop302
Old 07-07-2012, 09:15 AM
Boss_Hotrod
Boss_Hotrod's Avatar
Looks like the rollers out of the bearing. Been a while since I tore a t5 down but once you take the throwout bearing retainer off shouldn't the input shaft slide out? I know you have to do something funny with the output shaft to get it out but I cant remember exactly what it was.
Boss_Hotrod is offline
Old 07-07-2012, 12:07 PM
Goosepoop302
you have to rotate the shaft so a cut slot lines up with the counter shaft. i have done this but it would appear to me that the blown up bearings are jambing the shaft in place... i may be wrong but this thing is frozen on tiiight. http://www.astroperformance.com/prod...roducts_id/690
this is currently my next option if this transmission cant be fixed, anyone know anything about it??? i know i will need at least a new third gear for the main input shaft and the counter shaft gears plus the rebuild kit is already probably close to 500
Old 07-07-2012, 12:32 PM
mattdel
mattdel's Avatar
yikes. that thing went boom, eh?
We've had a couple guys here that used astro trannys. I'm not sure if either post anymore but I don't recall them having any issues. They've been around for quite some time(astro).
mattdel is offline
Old 07-07-2012, 12:44 PM
Goosepoop302
yeah there as very little fluid in the trans when i took it off so im sure that played a role. for a grand i guess a rebuild with some sort of warrenty seems like a half decent deal, i was hoping to rebuild mine but if the input shaft or any other part besides a gear or 2 i think its just gunna cost as much anyway
bradleyb
11-27-2015 07:50 PM
Dokilar
15
10-16-2015 08:13 PM
KingRando
10-02-2015 08:06 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: input shaft bearing
