intermittent low-speed miss 89 5.0
Newbie here- hope I have the correct forum.
My buddy has an '89 convertible with a high output 5.0 and he is troubled by an intermittent miss. New plugs, wires, new 10-pin connector from the dealer, (looks like a recall sticker for this) cleaned injectors, so far. I put my scan tool on it (Actron CP9110) and was disappointed to see we could not view data to catch it in the act. Looks like that capability was not available until '90.
Anyway, the rough running always occurs before 2000 rpm and under load. Above 2K it runs smooth and strong. It comes and goes. Sometimes will be OK for days, then acts up.
It has set no codes. The MAF was changed for a known good unit - same problem.
Any ideas?
Can the computer be changed for a '90 so we can scan the data while it is acting up?
Thanks,
Any ideas?
Thanks,
RE: intermittent low-speed miss 89 5.0
ive cleaned everything but havent changed plugs or anything because they were changed a year ago and i do nto dive taht much. i took al the plgus out and they were still good.. rotor and cap were kinda brownihs dusty inside.. fuel filter was clean enough.. someone had a similar problem and he replaced his ignitor/coil and he was good to go.. bt i havent had time to try it since i am a katrina refugee
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
