AC question on 91 LX.....
+1 W/ mjr46. The only way to truely tell if its charged correctly is to see the pressures on both the high side and low side. Those will vary with the outside temp and humidity, but the rule of thumb I always go by is the low side should run around 40 and the high side shouldn't be more then 350. That's after taching the motor up a little (like 1500 ish) and letting the pressures settle out. The gauges they sell you at walmart w/ the refrigerant will only tell you the low side
I dont mean to hijack this thread but what im asking is definately related
I have a 93 LX and the AC does not blow cold but it does blow. How do I figure out if it has been converted to the newer refridgerent? If it has not been converted does anybody know the approx cost to convert it?
Im very clueless when it comes to AC.
Thank you!
Thank you!
Thank you!
Thank you!
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
