How to Remove Flywheel?
I need to have it resurfaced before i get my new clutch in. I can't get the stupid bolts loose though. The engine keeps turning when i try to loosen them. I had a buddy try and hold the crank bolt but he couldn't keep it from turning. I don't have any air tools or anything like that so i'm just using a really heavy 2'-3' breaker bar.
Any ideas?
Any ideas?
There will be locktite on them probly blue. Heating the heads of the bolts up will help loosen the locktite up. If you cant stop the engine from turning by holding the balancer nut then there is definatly locktite on it. Heat will loosen it. trust me
Alright i'll try. I'll see if my little butane torch does the trick.
That would be a no on the tourch because of the rear seal i agree. in place of trying to hold the bolt on the front you should be able to wedge a large flat screwdriver in the teeth of the wheel. put a bolt in one of the bell holes and use that as a wedge point. better than a screw driver is a pry bar but it depends on the tools you have available
Harbor Frieght sells a fly wheel turning tool thatll grab the teeth in 2 places for like 10 bucks.........or craftsmen for probably like 20. Whichever way you go (buying the tool or a pry bar) don't bitch up the teeth on the flywheel or it'll cause ya problems later.
