where did my bottem end power go?!!
allright guys here it is. just upgraded to a performace products 70mm throttle body w/ the matching egr spacer. plus a C&L 76mm maf w/ the 76mm inlet pipe..tryed to put my cold air intake back on and the car wouldnt idle. stuck the cone filter on the end of the mass air housing (just like c&l suggest) and it idled perfect. the car is making much more power at higher rpms but ive lost all bottem end power...its bad. i cant even break the tires losse from a dead stop. what am i missing? do i need more fuel?
allright i did some reading and i got whatcha mean by clock the maf...its unneccecary now because i dont have the cai setup. i have the air filter attached directly to the maf housing in a short ram air style setup
Larger pipe = more airflow. Larger intake, exhaust and camshaft all increase airflow for high rpm use, but the low end suffers due to the lack of restriction. It's a tradeoff.
You shouldn't lose much low end because you are still going into the same intake manifold runners and heads.
What color tube did you get with your MAF? Should be GOLD.
http://www.cnlperformance.com/calibration.html
Yep. They sent me a blue one for my 73mm with 24# injectors. I checked C&L's website and it said I needed a brown tube. I called C&L and she told me that I needed the Brown tube and that it would make 5 more hp than the blue one. I called LMR and told them that their chart was wrong. They sent me the brown tube fore free. I guess the never bothered to check and update their info.
ive got the gold tube. i knew there was gonna b a change in the power curve i just didnt realize it was gonna b this drastic. the car screams at high rpm's now. what do u suggest i do to regain bottem end power?
