battery keeps dying
battery keeps dying
Problem here. 79 mustang 302. Replaced battery. alternator. Solonoid. Key tumbler.the only thing I haven't changed is the ignition switch next to tumbler. Car runs great but next day go out to start it and its totally dead. Could ignition switch be causing that..sometimes I have to turn key five times for it to start. Any help would be great
You need to verify were the draw is coming from. Put your voltmeter in-line on the positive battery terminal and start pulling fuses till the draw goes away. Put the fuse back in. Then narrow down what's in that ciruit and disconnect things till the draw goes away. That's what you gotta change to solve the problem........If it's killing it in one night it's gotta be a big draw.
logan409
09-26-2015 07:43 PM
