Old 11-04-2015, 11:46 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Car running hot...how to flush radiator?
Old 07-22-2012, 08:14 AM
Tha Boss
Tha Boss's Avatar
Default Car running hot...how to flush radiator?
Have had my 88 stang for two years and have a racing aluminum radiator in the car. Never ran a thermostat. Car startd running a temp so i installed a thermostat but that didnt work. Gonna flush the radiator. Wondering how you guys do it.
Tha Boss is offline
Old 07-22-2012, 05:29 PM
Js88lx
Js88lx's Avatar
Iv just unplugged the bottom rad hose and stuck a hose on top and flushed out.
Js88lx is offline
Old 07-23-2012, 12:41 AM
mattdel
mattdel's Avatar
Check here http://www.prestone.com/products/print/424?popup=1
Using a hose won't really work to clear it out, it's only effective to test flow. The residue that builds up needs a chemical reaction to break it free from the metal it's stuck to.
Hence,
mattdel is offline
Old 07-23-2012, 01:04 AM
Bladerunner
Bladerunner's Avatar
Your radiator is probably the culprit.
Your radiator is more than likely clogged/corroded and needs
to be replaced.
If you search their are alot of good aftermarket replacement radiators
out there.
Bladerunner is offline
Old 07-23-2012, 07:58 AM
Tha Boss
Tha Boss's Avatar
I flushed the radiator and car does a lil better but still running warm. Drove car yesterday and car got over 210. So i stoppd snd let the car sit and it stabilized at 210 and didnt go up anymore. One of my friends says it could be a water pump issue
Tha Boss is offline
Old 07-24-2012, 01:51 AM
Bladerunner
Your radiator and your water pump would be the two places
I would look.The water pump failed on my friends 94 GT and it
would overheat everytime he would try to drive it.
I would start looking at new water pumps.
The stock one core radiator can only cool so much though.
djbigskrilla
09-20-2022 01:04 AM
jjwinel78
08-17-2015 03:34 PM
jdphillips73
08-16-2015 04:34 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car running hot...how to flush radiator?
