Uneven Idle
Uneven Idle
Hey all
Here in good ol' California I am having to smog my 1994 5.0L 5 speed and having a bit of trouble. Any quick ideas for what would cause an uneven idle? It is kicking the car out of the smog system. It seems to idle around 800 RPM but goes about 150 RPM to either side of that.
I have been checking for EVAP issues but can't track any down.
Thanks!
Thanks!
Sorry, I wasn't very clear. It does not drop down to 150 RPM, it drops 150 RPM, to just above 600 RPM or so, and then goes up to just over 900RPM. There is no CEL normally, though it does sometimes come on briefly when on the freeway or under heavy acceleration.
The only other issue with the car (really the BIG, main issue) is that it has a very heavy vibration from about 2100 RPM to 2500 RPM and from about 3500 RPM up to ???. I thought this was something in the driveline, but it is now occurring in neutral or with the clutch in.
Thanks for the help you guys.
when that cel comes on it stores a code in the computer.
The vibration is most likely in the drive line even in N with the clutch in the drive shaft is still moving. Could be a bad u joint. Mine went bad but you couldnt tell till i took the drive shaft off and checked . the front ujoint was siezed up part way .
