86 cooling system
Old 08-09-2012, 02:14 PM
429Boss
429Boss's Avatar
Exclamation 86 cooling system
I recently bought a 86 Mustang GT and discovered that it has a cracked cooling fan and a radiator with bent cooling passages and a lot of broken fins. I'm going to replace both of them with aftermarket parts, does anyone know of any good brands to look into? The engine is stock and for a little while its going to stay that way before i rebuild the engine. Thanks guys
429Boss is offline
Old 08-09-2012, 02:34 PM
Tony71502
Tony71502's Avatar
Get a stock replacement fan, the aluminum flex-a-lite ones make a lot of noise. Stick with a stock radiator replacement for now. It's useless spending a couple hundred dollars more on a stock car. Just my 2 cents. I've had no cooling problems at all running a stock radiator with basic bolt ons, under drive pulleys, and a cam.
Tony71502 is offline
Old 08-09-2012, 06:53 PM
429Boss
429Boss's Avatar
Fan blade noise isn't a problem and for a slightly better than stock fan the price difference isn't that substantial. But you make a good point the aftermarket radiator im looking at is over $100 more and if you haven't had a problem that makes me feel more confident but for only a couple dollars i feel that a better fan is money well spent for insurance.
429Boss is offline
Old 08-10-2012, 07:34 AM
Tony71502
Tony71502's Avatar
The fan noise from the metal blade fans is very noticeable. The only thing that quieted mine down was putting under drive pulleys on to slow it's speed. This also slows the water pump down.
Old 08-10-2012, 02:47 PM
429Boss
429Boss's Avatar
that's why i'm thinking of switching to an electric fan to avoid that problem. but will that lead to any water pump problems if i remove the stock fan?
429Boss is offline
Old 08-11-2012, 12:06 AM
Tony71502
Tony71502's Avatar
No. None at all. Just don't get a cheap electric fan. Make sure the shroud gets your whole radiator and make sure you have a temp relay. Elec fans are much better than mechanical... but to do it right... you are going to spend money. Don't half *** it.
Old 08-13-2012, 12:10 AM
429Boss
429Boss's Avatar
i agree completely and thanks for the help
429Boss is offline
Old 08-15-2012, 04:19 PM
2011scgt
2011scgt's Avatar
i would indeed throw a 3 row rad in it. i would find a police fan and install it. the only good thing about a flex fan is it can cut down on weight. adding an electric fan will need an alt. upgrade as these stock are 75 amps. i would also put in a 185 mr gasket stat.
2011scgt is offline
Old 08-16-2012, 07:31 AM
Tony71502
Tony71502's Avatar
I'm pretty sure Special Service Mustangs didn't come with electrical fans. Flex fans don't really weigh that much less than the stock fan. The difference is inertia, there is less material far away from the rotational axis. There is no reason to replace the thermostat.
Old 08-16-2012, 06:40 PM
2011scgt
2011scgt's Avatar
they only make the clutch for the fan. actually the flex fans are lighter than stock...and yes replace the stat to the one i said..they have a larger ofice(opening) and being 185 degrees helps also they are balance no need to purge the system.. i use them in all my fox bodies
2011scgt is offline
Quick Reply: 86 cooling system
