94GT electric window problem
Old 08-11-2012, 11:15 AM
glenb
glenb's Avatar
Default 94GT electric window problem
electric window on drivers side will go up and down if i pull or push on window. The elec motor is still running but window stays in one position. It almost seems like a stripped gear. Is this possibly the problem. I have the door panel and plastic off, but really cant see in there good enough to see a gear or track near motor. Newbie to site but seems to be some good tech info here. Thanks for any info you can give me.
glenb is offline
Old 08-11-2012, 12:36 PM
mattdel
mattdel's Avatar
Most likely the motor is weakened to the point of no return. The gears almost never strip, as they're steel.
mattdel is offline
Old 08-11-2012, 07:27 PM
Bubba 95SN
Bubba 95SN's Avatar
Plastic pieces(3) and plastic gear that rides on metal worm gear are likely culprit. Window motor reepair kit about $25. Lot cheaper than new motor.
Bubba 95SN is offline
Old 08-15-2012, 03:21 AM
ttocs
ttocs's Avatar
can you hear/feel the gears grinding when you move it? If not then I would question the regulator if not then maybe the gears/bracket.
ttocs is offline
Tivo304
08-28-2023 12:19 PM
articman
06-21-2018 11:45 PM
zanemoseley
09-06-2015 12:58 PM
cbird1177711
09-03-2015 08:43 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: 94GT electric window problem
