Exhaust Fumes in Car- Suggestions?
Old 08-16-2012, 04:08 PM
AAX86
AAX86's Avatar
Default Exhaust Fumes in Car- Suggestions?
I've had a problem with really bad exhaust fumes in my car since i bought it. If i'm really light on the gas it doesn't really stink too bad but if i drive like my normal leadfoot self it starts to smell pretty strong inside the car. And if i really get on the gas it just stinks bad like straight exhaust. When i had the stock h-pipe on the car it smelled like exhaust too and it still passed smog then so it's not an exhaust leak. Now there's an offroad h-pipe on it and it still smells like it did before. If it's not an exhaust leak what could it be?
What are some likely places to seal off the smell? I just sealed off the shifter opening with caulking but it didn't do me any good. It stinks with the windows up or down. It might smell a bit more with the windows up actually.
Any suggestions?
AAX86 is offline
Old 08-16-2012, 04:15 PM
mattdel
mattdel's Avatar
I suggest you find the exhaust leak. The laws of physics demand that you have a leak close to the HVAC vents to be able to smell exhaust inside the car with the windows up.
mattdel is offline
Old 08-16-2012, 05:13 PM
AAX86
AAX86's Avatar
b-b-but it passed CA smog.. i thought they fail you if there are any leaks.
Where are the HVAC vents?
AAX86 is offline
Old 08-16-2012, 06:56 PM
2011scgt
2011scgt's Avatar
is it a full exhaust or dumps? if full exhaust put your hand on the end to close it off and listen for leaks..is the car running rich?
2011scgt is offline
Old 08-17-2012, 02:38 PM
AAX86
AAX86's Avatar
Wow that sounded dumb now that i read it again. I didn't mean what vent inside the car. I meant what vent is there around the exhaust?
AAX86 is offline
Old 08-17-2012, 02:45 PM
Tony71502
Tony71502's Avatar
It pics up air at your cowl area. Exhaust from underneath also will come through the floor where there are holes, like the shifter.
Tony71502 is offline
Old 08-17-2012, 10:51 PM
Js88lx
Js88lx's Avatar
the plugs under your spare tire..., check those!!!
Js88lx is offline
Old 08-20-2012, 01:32 PM
mo_dingo
mo_dingo's Avatar
Factory exhaust?
mo_dingo is offline
Old 08-20-2012, 04:53 PM
AAX86
AAX86's Avatar
Originally Posted by mo_dingo
Factory exhaust?
Nope. O/R h-pipe and flowmasters but i had this problem even with the factory h-pipe on it.
I have yet to find the source of the smell. I'll check the spare tire compartment today but last time i looked i didn't see any holes. meh
AAX86 is offline
Old 08-21-2012, 08:18 AM
Tony71502
Tony71502's Avatar
Did you check for exhaust leaks? If you're smelling it in the car like that it has to be leaking somewhere. If your exhaust has no leaks in it, which you say passing smog=no leaks, it will not smell inside the car.
Quick Reply: Exhaust Fumes in Car- Suggestions?
