Pushrod Help!
now go to your local toy store and get a can of play dough so you can measure for ptv that of course is if you haven't bolted/torqued the heads down, I use a old head gasket for mock up of the same thickness of the one I will use in final assembly, I took my daughters play dough for my current project, hope she doesn't miss it..lol
The heads are torqued down since I was trying to measure the pushrods. I have checked w Probe Industries on how much lift the pistons can be used with (.600), should I still measure them? I have .579/.579 valve lift
The clay method seems the most popular and I already own a dial caliper.
Have you used the method where the head stays on, and you rotate the motor until you are on the end of the exhaust/beginning of intake, and let the valves drop into the cylinder? Then measure the distance in between the rocker arm and valve stem with a feeler gauge? I would have to measure multiple times but I wouldnt have to take the heads off
Again, thanks for all the help guys
