Starting issue.
Old 09-01-2012, 05:48 PM
Digger86
Digger86's Avatar
Default Starting issue.
Only owned the car a week. So heres what happened. Was driving it. It was running fine. Parked it and left to go walk around. Cam back car wouldnt start. was low on gas so i thought i was out. Put gas in it and it still wouldnt start. So checked and had no spark. Put new tfi in it now have spark but still wont start or even try. Even tried with starting fluid still nothing. So could it be the distributor or the pickup coil? Its a 1986 5.0 . Has new msd coil and cap. but still the old distributor. Any advice would be grand thanks in advance.
Digger86 is offline
Old 09-01-2012, 06:03 PM
mattdel
mattdel's Avatar
pickup coil probably. fuel pump relay is under the seat, make sure its working too.
mattdel is offline
Old 09-01-2012, 06:06 PM
Digger86
Digger86's Avatar
ok ive got fuel because i can smell it for one. Its just weird that it wont start with starting fluid.
Digger86 is offline
Old 09-01-2012, 08:15 PM
Digger86
Digger86's Avatar
ok update now have no spark and weak spark coming out of the coil. Could it be the coil pack?
Digger86 is offline
Old 09-01-2012, 11:49 PM
mattdel
mattdel's Avatar
weak spark is usually an indicator of a failing coil, yes.
mattdel is offline
Old 09-02-2012, 11:27 AM
Digger86
Digger86's Avatar
also I have 12 v to both wires on the coil.
Digger86 is offline
Old 09-02-2012, 12:17 PM
mattdel
mattdel's Avatar
Well, that shouldn't be. The dark green/yellow wire should be ground, it's also the TFI ground. It originates from pin 4 of the ECM, has a 22k ohm resistor inline, then splices out to both from there. It receives the ground from pins 40 & 60 on the ECM, which are tied directly to the battery negative terminal grounds, which should be block & frame.
Check your main grounds, and check to see if the corresponding pins I've mentioned are grounded or 12v. I'm thinking the end result here is gonna be a dead ECM.
mattdel is offline
Old 09-02-2012, 12:50 PM
Digger86
Digger86's Avatar
I'm testing that with key on. so maybe its back feeding or something and thats with it plugged in.
Digger86 is offline
Old 09-02-2012, 04:08 PM
Digger86
Digger86's Avatar
update thanks for the help. my 3 month old coil pack went bad.
Digger86 is offline
2007StangV6
01-28-2016 06:09 PM
MusicCity615
09-12-2015 07:05 AM
zanemoseley
09-06-2015 12:58 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Starting issue.
