Weird stuttering
Weird stuttering
i have a 94 5.0. The engine stutters and bucks unless i REALLY get into the throttle. After it drives for a while, it seems to be less pronounced but still exists. Even with the engine warm, if i restart the car it will do it all over again, even if its already at operating temp. I have replaced:
Fuel Pump
Fuel Filter
ECU
Cap, Rotor
Coil
TPS
MAF
Plugs, Wires
Timing is perfect
i am at a loss -- the computer is a 90. The car had a 5 speed but i swapped in an AOD. Thats the only weird thing. The engine is stock.
any ideas?
Fuel Pump
Fuel Filter
ECU
Cap, Rotor
Coil
TPS
MAF
Plugs, Wires
Timing is perfect
any ideas?
Sounds emissions system related, EGR, EVP.
Run codes. http://sbftech.com/index.php?PHPSESS...d&topic=2471.0
okay i'll try the engine coolant temperature sensor -- cheap fix. Then move on to the emissions stuff if that doesnt work. The problem is also i have a lot of smog codes thrown on the ECU because the smog stuff was removed. Dont need to smog a 61
Before I read your list I was thinking TPS or MAF. Next I was thinking a vacuum leak.
Sure would be nice to have a wideband hooked up to see what the a/f is doing.
I'm not too familiar with these older 5.0L so I'd listen to guys like mattdel first.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
mungodrums
09-28-2015 10:54 PM
stangin1996gt
09-21-2015 11:01 AM
