92 mustang steering isnt tight
Old 09-17-2012, 10:00 AM
adriansayre
adriansayre's Avatar
Well im not to sure if that would be the problem but ill look im just wondering why little effert, do u think that if I change the rag joint if that would help
adriansayre is offline
Old 09-21-2012, 08:45 AM
NickP87
NickP87's Avatar
If the wheel is turning too easily try putting an underdrive pulley on the power steering pump. That would make it work less & should move less fluid so it should make the wheel harder to turn.
NickP87 is offline
Old 09-21-2012, 09:14 AM
Tony71502
Tony71502's Avatar
This is not a good fix. This can result in dangerous situations.
If responsive is what you are going for. A steering shaft without a rag joint will give you less play when turning.
Tony71502 is offline
Old 01-18-2013, 02:25 PM
Alyssa ducky
Alyssa ducky's Avatar
Default 92 fox body must convertable steering issues
ive been fixen up my stang, but now the i am having to way over steer when turning. I am trying to figure out how to go about fixing this. i have never worked with steering before.
Alyssa ducky is offline
Urambo Tauro
12-17-2016 03:30 PM
SANDY21
08-17-2015 02:41 PM
ccwebb
08-11-2015 06:47 PM
daytooday
08-11-2015 09:22 AM
Itstbrown
08-09-2015 03:49 AM
Quick Reply: 92 mustang steering isnt tight
