Fuel Injector Cleaning? Help!
Old 09-29-2012, 11:21 AM
The Beef
The Beef's Avatar
Exclamation Fuel Injector Cleaning? Help!
I got a 1990 Mustang Gt from my sister about a week ago. It was sitting for at least a couple months, probably closer to a year. I have run through a few tanks of gas as well as some STP cleaner I added to first tank of gas. It is running a heck of a lot better than I first got it but RPMs still want to drop then pick back up to 700-800 which is the normal idle RPM. I was thinking some gunk got into the fuel injectors and was wondering if anyone has any suggestions for cleaning them. Any help is greatly appreciated! I'm not super savvy with cars yet so any suggestions with detailed explanations would help a lot. Thanks everyone.
The Beef is offline
Old 09-29-2012, 11:32 AM
TRexGAWD
TRexGAWD's Avatar
It could be other problems besides the fuel injectors.. fluctuating idle most likely points to an IAC problem.
TRexGAWD is offline
Old 09-29-2012, 11:39 AM
The Beef
The Beef's Avatar
Thanks a lot T Rex, I will give this a shot. I honestly don't know how to go about this since I know very little about cars, but I got my Haynes manual and the internet so its time to do some reading. If you have any links or guides on cleaning the IAC it would really help out a lot.
The Beef is offline
Old 09-29-2012, 11:44 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
The injectors are typically cleaned by chemical. Whether it's a tank additive or a professional grade can hooked up through the fuel system. Most likely they are NOT the problem. Try some of the suggestions already posted in your other thread.
PRO50SC is offline
Old 09-29-2012, 12:05 PM
TRexGAWD
TRexGAWD's Avatar
It's pretty straightforward.. It's a little tube looking thing on the side of the throttle body.. just unplug it and take it off and give it a good cleaning.. Let us know if that solves the problem.. If not we can go from there.
TRexGAWD is offline
Old 09-29-2012, 12:15 PM
The Beef
The Beef's Avatar
what would you recommend cleaning it with?
The Beef is offline
Old 09-29-2012, 12:18 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
carb cleaner/spray usually works fine. Check your other thread.
PRO50SC is offline
Old 09-30-2012, 04:41 PM
furiousjoe
furiousjoe's Avatar
check this diagram to see where the iac is
http://www.fiveohinfo.com/fox/diagra...ram-drawn2.png
furiousjoe is offline
Old 09-30-2012, 05:48 PM
The Beef
The Beef's Avatar
Just wanted to update everyone. I cleaned the IAC and throttle body. I am happy to say, problem is fixed. Thanks so much to everyone for all the help. Greatly appreciated.
The Beef is offline
EZFEED
05-05-2016 08:54 PM
pimp2303
09-17-2015 08:45 PM
SteelerNation82
09-16-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Fuel Injector Cleaning? Help!
