94 gt passenger mirror not working
hey guys, just got a 94 gt conv and the passenger mirror isnt working at all. no movement or sound coming from the motor. I replaced the mirror with a different one and a different switch as well. Fuse is not blown. Any ideas?
so i hooked up a circuit tester to the wires, i got 12 volts at the green wire near the mirror 9 and 4 at the yellow and purple. the tester has different lights for each, it has 4, 9, 12. so i assume I have some bad wiring.
Check your wires at the front door opening inside of rubber harness cover, I'd bet you have some particle wires broke.
i forgot to add for anyone having a similar problem, i had 12 volts right out of the switch so i know the switch is good, the wiring goes in the door behind the kick panel, runs along the outer edge of the car udeneath the carpet and then up under the seats and passenger kick panel then out to the door.
