Overheating Mystery
There is no body kit, this car is bone stock. I keep thinking air flow problems too. In fact, I've even replaced the tranny cooler because I thought it might be stopped up and restricting air flow through the radiator. Is there a way to test the fan clutch to see if it needs replaced? It seems to be pulling alot of air through the radiator. Should I consider installing a pusher fan also and run it on a thermal relay? Is there supposed to be ventilation in the engine compartment to let the heat out like my Cobra? I really appreciate you guys trying to help me figure this out. I'm at a loss on how to proceed.
steve
There's a few ways to check it.
http://www.ehow.com/how_5086903_test-fan-clutch.html,
http://www.quadratec.com/jeep_knowle...rticle-109.htm, and
http://www.youtube.com/watch?v=qUN17UEUWmc
Thank you for posting the vid and articles. I studied them, then started the car and let it get to operating temp. I did not have a newspaper, so I rolled up a manila envelope and stuck it in the fan. It sounded cool (like a playing card in bicycle spokes) but did not slow or stop the fan. I then turned the car off and tried to spin the fan. I was able to spin it about 5/8 turn. No noise or wobble. Someone asked about the thermostat, I believe it is 180.
steve
Reason I recommend the gauge is because you simply can't tell temp in the stock gauge, it can be 200 and ok or 240+. Even when I had my Mach, I had air in the system, stock gauge reading below half (which was supposed to be normal) and my SCT tuner was reading 236 and slowly creeping up. I spent sometime troubleshooting an overheating issue on my 85, changed to an electric fan, flushed the system and nothing it still crept up on the stock gauge. Found a temp and oil pressure gauge for less than 100 bucks, found that even though temp never went over 210 in my drives, the cooling system didn't seem to be controlling once the Tstat opened.
steve
ok, so once you move away from traffic the temp drops, if you hit traffic again, does the temp creep back up, or does it only do it once and then the temp remains stable?
i would not try and increase the water pump pumping power - i don't think that is your issue. particularly because you have changed engines and the problem remains, sounds like gauge issue or system needs a good burp. have you done a coolant change recently?
