clutch fork allowable play
Old 10-01-2012, 05:14 PM
javila2468
javila2468's Avatar
Default clutch fork allowable play
i have a t5 z rated tranny. i was adjusting the clutch cable over the weekend and noticed that the clutch fork has movement 2 different ways...looking up from the bottom of the car, the fork has movement both horizontal (pushes against pressure plate) and vertical movement?
Is that acceptable or could something being messing up?
only thing i'm feeling different is a 2nd gear grind only at high rpms or if i shift too quickly.
javila2468 is offline
Old 10-02-2012, 01:44 PM
mattdel
mattdel's Avatar
Vertical will always be there as the fork is secured on a ball socket, but it shouldn't be very much at all. If you can offset the fork enough so that its no longer centered, you got issues.
mattdel is offline
Old 10-02-2012, 02:03 PM
javila2468
javila2468's Avatar
its centered just fine...just a slight vertical movement...
Old 10-02-2012, 02:04 PM
TRexGAWD
TRexGAWD's Avatar
How much play? Give a measurement..
TRexGAWD is offline
Old 10-02-2012, 02:36 PM
javila2468
javila2468's Avatar
about an inch to inch an a half...its not loose...it does require a bit of pressure to move it vertical.
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: clutch fork allowable play
