Harmonic Balancer installation, quick question
Old 10-03-2012, 05:44 PM
dawson1112
dawson1112's Avatar
They make a tool to hold the balancer so you can torq it but like i said a piece of long flat bar with some holes drilled in it to match the holes in iether the balancer or the rear end of the crank where you bolt the flywheel on . if you get somthing that you can bolt up on it like a handel it will help out.
dawson1112 is offline
Old 10-03-2012, 06:02 PM
Duncan_GT
Duncan_GT's Avatar
Oh ok, I see what you're saying. Do you think it will hurt the key ways to hold the balancer like that?
Duncan_GT is offline
Old 10-03-2012, 07:14 PM
Duncan_GT
Duncan_GT's Avatar
This is as far as we could get it, my buddy held the threaded stud of the tool so the balancer wouldn't move and I put torqued the nut. Does this look like its on all the way, or should the crank snout be flush with the balancer (pics 2 & 3)?
Old 10-03-2012, 08:21 PM
dawson1112
dawson1112's Avatar
it looks all the way to me. The crank spout should not be flush with the balancer other wise the washer that holds it on does nothing but tighten on the crank. If in doubt put the pullys on and check the alighnment of the belt. Im sure its on all the way though.
You really dont want to force the tool to push it any more or youll end up pulling the threads out of the crank snout.
Old 10-04-2012, 07:48 AM
javila2468
javila2468's Avatar
cylinder stop causing cylinder to break?!?! pshhh!! use rope buddy to stop the cylinder.
javila2468 is offline
Old 10-04-2012, 08:06 AM
Duncan_GT
Duncan_GT's Avatar
Yeah the tool that fits in the spark plug hole to stop the piston. They said I'd run the risk of snapping the tool off inside the cylinder and damaging the spark plug threads
JonnyBlazeGT
11-03-2015 01:10 AM
richard1027
09-09-2015 07:23 PM
richard1027
09-08-2015 01:24 PM
1987gt40ttopt
08-28-2015 10:49 PM
Urambo Tauro
08-27-2015 10:53 AM
Quick Reply: Harmonic Balancer installation, quick question
