smog pump system help
Old 10-08-2012, 07:34 PM
  #21
OIFVET
OIFVET's Avatar
as i was getting everything ready for the swap today, i realized that the guy who owned my stang before me had off road H pipes on it. there is a portion of the smog tubes that is plugged up. then it hit me, if he got rid of the stock exhaust there isn't a line running to wear they used to be. I still have the H pipes one with a couple high flow ceramic cat's that i got welded on there. I'm gonna run it through tomorrow and see what the deal is, but i'm thinking that i wont need it for the sniff test. but on the flip side with it hooked up the idle acts stupid. I had planned on replacing the valves today but if there's no line for the cat's what the hell is the point?
OIFVET is offline
Old 10-09-2012, 12:05 PM
  #22
OIFVET
OIFVET's Avatar
i appreciate all of the help and advice from y'all i just ran the car through emissions with out the catalytic converter line so it was basically as if i didnt have a smog pump and it passed with flying colors...now for the delete kit!
OIFVET is offline
Old 09-01-2014, 02:25 PM
  #23
SWGSSSlacker
SWGSSSlacker's Avatar
So....
I have a 1990 Notchback without cats, it still has the smog pump and all its plumbing and is currently being driven by the serpentine belt. If I totally remove the smop pump and go with a shorter belt or delete kit should the car pass an emmisions test. I live in Texas and emission testing is mandatory. It was inspected May 2014 before I owned it and apparently passed. I have read this topic so I just want to be sure I do the right thing. Should I get cats put inline before I remove the pump or not? Should I just remove the pump and be done with it. The A/C has been converted to 134A so I will continue to use it, living in Texas it's a requirement.
SWGSSSlacker is offline
Old 09-01-2014, 07:04 PM
  #24
65Raven65
65Raven65's Avatar
Originally Posted by SWGSSSlacker
So....
I'm in Texas too. Once your car is 25 years old, which is next year, they wont sniff test it. Safety inspection only. I just got mine inspected, it cost like $13.50 or something. Awesome.
Dump the smog crap and don't look back!
65Raven65 is offline
Old 09-01-2014, 07:20 PM
  #25
65Raven65
65Raven65's Avatar
Also, I've never understood the advantage of running a smog pump delete pulley. Chunk the pump in the trash can and run a shorter belt. Less crap under the hood, less rotating parts to wear out, and a WHOLE lot cheaper.
YMMV
jwog666
12-27-2021 08:09 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
09-24-2015 09:18 PM
Quick Reply: smog pump system help
