SOMEONE HELP ME PLEASE!!!
k guys,here's the prob,90 gt 5.0 ,sits and idles like crap,all the power is there when i give er,just idles terriable,and super rich,like burn your eyes in 3 mins rich,i have been through all the post on here,and cant seem to get er,i also have an 87 that runs perfect,looked at it to make sure all was the same,only thing diffrent is the smog stuff is deleted,i've tried it all,even the new computer,when it idles it sounds like a lumpy cam,but worse,only mod i know it has is 70mm tb,and i think shortly headers,even went into the timing chain to check er out,and all was well,swapped out injectors no change,also did iac,tps(voltage is .98)plugs,wires,thermostat,even pulled the whole plenum off of buddies motor to see if that did anything ,I got nothin guys,i am lost,love the car,but why do they have to fight so hard hahahaha any help would be greatly appreciated.
thanx
Mike
thanx
Mike
Get your hands on a laser thermometer ($40 at harbor freight) and give this test a whirl: https://mustangforums.com/forum/5-0l...l.html#2355308
Also try swapping the MAF out if the 87 has been converted.
I had a similar issue before. First i replaced my Idle air control valve. the one that hangs off the side of the Throttle body, that didnt help and i kept having issues. weird backfires and things. it turned out to be a plug on the ground cable cut and spliced it and it ran fine from then on.
