Weird Noise When RPMs Drop
Hey peeps, i'm hoping you guys can help me figure out what's causing this noise.
Basically, whenever the Rpm's drop from about anything above 1000rpm, it makes this nasty kinda clunky grinding sound. It's not too loud but it's loud enough to notice it. It doesn't matter if the car is still or moving. I can hear it when i shift and also when it's revving at a standstill.
The noise started immediately after i changed the h-pipe yesterday so i'm hoping it's just exhaust-related.
I just replaced the clutch a few months ago and it only has a little over 1,000 miles on it. That included a new pilot bearing, throwout bearing, flywheel, etc. so i'm hoping it doesn't have anything to do with the clutch.
Do i need to re-check the exhaust? Everything felt tight yesterday.
Any help is appreciated, Thanks
Id say its probly something on the exaust is loose and hitting the floor pan like mattdel says. I almost always have to retighten flange bolts after they get hot a few times after a new install. Mine kinda did the same thing when I first replaced the cats with some mid pipes. Turned out that the one side was just a bit short and the front of one muffler was rattling against the floor pan where it is recessed for the mufflers to go .
So, i checked the exhaust again, tightened everything up good (only one bolt was a little loose), and the pipes and mufflers had plenty of space between the floorboard. Started her up and no improvement. It's still making the sound.
It sounds like it's coming from up front. Around the bellhousing. Maybe the headers. I can't tell for sure.
Any other ideas what it might be?
I'll keep trying
Alright i got a video of it but it might be a bit hard to hear without earbuds or headphones unless you turn it up loud. I wasn't trying to rev on it too hard cause the engine was still a little cold but you can hear the sound after every rev.
Any new ideas?
oops.. Can't embed for some reason.
Here's the link:
Any new ideas?
Here's the link:
