stupid lock smith
Old 10-31-2012, 12:53 PM
atomicboom21
atomicboom21's Avatar
Default stupid lock smith
Ok.My car would crank then continue to try and crank itself while its running "weriod" I know. i don't have a key it wouldn't turn so i called a lock smith. He came out and started to drill out my tumblers and then had to leave without finishing the work. Now i am in a f'd up situation. How and where do i start this complex surgery.
to fix this problem i a changing the ignition switch, the engine managent switch and the starter selonoid and the starter. Hopefully that will fix the problem.
atomicboom21 is offline
Old 10-31-2012, 01:37 PM
dawson1112
dawson1112's Avatar
Well without a key to turn the ignition you may as well finish drilling out the tumblers, cause the key has to turn in order to push the pin in that holds the key switch inside of the column. Other wise its a tedious job of cramming a screwdriver in and trying to break it. Trust me the drilling is necessary with out a key. Youll need to remove the plastic housing from around the colomn then once you do that youll see the key switch and once you drill it out enough and can turn it youll see a pin ( and I can remember if it top or bottom ) that holds the switch inside of the colomn.
dawson1112 is offline
Old 10-31-2012, 01:52 PM
atomicboom21
i found a white button on of the steering wheel and tryed that but nothing happened. i can see a peace of plastice in the back but no turning affect.
Old 10-31-2012, 02:12 PM
dawson1112
dawson1112's Avatar
If you cant turn the cylinder as if the key were in it you dont have it drilled out enough. It is not as simple as running a drill bit in there a few times your gonna have to probly graduate to a bigger and bigger bit till you can turn the lock as if a key were in it.
Then you have to take the plastic cover off of the steering colomn to get to the pin It will be small like about a 1/16 inch diameter pin.
Old 10-31-2012, 02:30 PM
atomicboom21
If I could post this pic u could see where I'm at. I was using a bit and it turned the tumbler a little bit but not far enough.
Old 11-03-2012, 09:23 PM
billison
billison's Avatar
if the whole thing is already drilled, there is really nothing to risk. a new ignition is like 13 wih two new keys, go buy one so you know what is what, drill till you can turn it, then replace it.. Good luck!
billison is offline
Old 11-04-2012, 03:51 PM
atomicboom21
got the key fixed thanks for your help and tips. And know i have another problem with the clutch cable. it just popped of and left my clutch pedal limp..
BOB ROME
07-26-2023 01:54 PM
guitarman376
09-30-2015 05:54 PM
logan409
09-26-2015 07:43 PM
09-25-2015 06:58 PM
Quick Reply: stupid lock smith
