please help (waterpump)!!!
ok guys so I bought my first foxbody a few months back and needless to say I LOVE IT! but I have a problem the waterpump started leaking so I decided I would change it well in the process I broke off a bolt into the block so I drilled and helicoiled the hole, in the process I drilled a little to far and water started coming out of the hole just wondering now if anyone knows if this is a big problem or if water and oil will mix? THANKS IN ADVANCE.
here is a pic its not my block but to give you a idea the hole is circled in red
http://www.freeimagehosting.net/ykrnz
I wouldn't think you'd have a mix as a result, I imagine it's only water passages right there. I'd try to find where the hole is just to be sure, maybe even bring the block to a machine shop and see what they say. Chances are good all you need to do is put some silicon on the bolt, like you would with heads.
well as promised I am reporting back to let you guys know how it went and it wasnt well water and oil was mixing I added a pic to show which bolt hole it was on the block (not my block) but on the up side it gives me a chance to do the build myself and the way I want it
Gary Ugarek
09-05-2015 09:03 PM
